LFB
Mar 21, 2025Follower
ORBI network 970 is slow
Upgraded from Orbi to Orbi 970. More compatible with 2.5GHZ and faster. It is so slow you can't watch Amazon Prime. Also my throughput, speed, fell from 425-450 to 40-60. I have one router and two satellites. Now only using one satellite. My old orbital had two satellites. Help?
What prior Orbi model did you have?
Does this happen with the RBS turned OFF?
How are you streaming Prime, Wireless or wired?
How are you speed testing? Wireless or wired?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.What is the size of your home? Sq Ft?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter. - FURRYe38Guru - Experienced User
Any progress on this?
