Buphett
Mar 03, 2024Aspirant
Orbi RB973 Connect to printer
Cannot connect HP wireless printer to new Orbi RB973 mesh system. Printer worked fine on previous Orbi mesh system.
- Mar 03, 2024
Using same SSID name and password from prior system?
Possible printer doesn't like mixed mode WPA2/WPA3 settings which the printer Mfr will need to help with.
Try installing the printer on the IoT network using WPA2 only setting.
Does the printer connect via ethernet if it has a ethernet port?
Contact the printer Mfr for help and support information regarding there product.
Mar 03, 2024Guru - Experienced User
