Neecho
Mar 11, 2025Follower
Orbi RBE771 and Satellite - wont sync.
Hi all I have just installed ORBI 771 router successfully. I am trying to install and sync the satellite. It shows on my app as having been added to the network but will not sync. I assumed ...
Mar 27, 2025Guru - Experienced User
New FW available:
Neecho wrote:
Hi all
I assumed it needed a firmware update but dont know how to do this without it connecting to the router.
So, after it was added to the network, i linked it to router by ethernet - it then synced with the router. I cannot say whether any firmware (i do not think it was).
I then removed it from the router and via the ethernet and placed it where it is needed. Now, when i switch the satellite on it states offline.
Can anyone help?
If its a case of the the satelitte needing a firmware upgrade why does it work on ethernet port? And if so how do i complete the firmware upgrade.
FYI i have factory reset the system twice already.
TIA
