shawzie's avatar
shawzie
Tutor
Dec 03, 2025
Orbi RBE771 lags every hour on the same minute
For the past 11 months my Orbi RBE771 lags every hour on the same minute from when it is booted. This lag lasts for about 30 - 60 seconds. I have tried disabling IPV6, Armor, Traffic Meter etc. The issue happens when wired to the satellites or connected over WiFi. This mesh system is used for gaming and it was purchased for its high speed 2.5Gbps ports on the satellites. The lag during gaming  is finally getting unbearable. I have updated every FW version that has came out this year but the problem still persists. Does anyone have a fix for this?
1 Reply
  • FURRYe38's avatar
    What do you mean by LAGs?
    Please give more details about this. What is happenging?
    What brand and model# devices are connected to the system?
    Is this happening at the RBR or at the RBS or both?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
