FredCC
Sep 28, 2024Guide
Orbi RBE772 - Teams meetings and video streaming drops/reconnects
New Orbi owner here. My Nighthawk R8000 worked flawlessly for 10 years and I decided to upgrade to the Orbi. From day one, Teams meetings on Dell laptop and video streaming from various platforms (Fa...
- Nov 06, 2024
v 10.5.10.184 fixed the issue. No more streaming issues and my Teams meeting was flawless. I had NG close the case.
FredCC
Sep 30, 2024Guide
Thank you for your input. I did a proper measuring of the distance between the RBR and RBS. It is 28 ft. direct path. Wireless backhaul. I had an audio Teams meeting this morning with the RBS powered off and the issue still persists. Audio dropped several times, Teams popped up a message saying that my network quality was poor. The meeting disconnected and automatically reconnected after about 5 seconds.
Channel configuration: 2.4 Ghz is set to channel 11. 5 Ghz is is set to channel 40. I left all other settings at their default factory setting. Enable 20/40 MHz Coexistence is checked. Preamble set to Automatic.
The ISP modem is secured to the wall with the label against the wall. I can't remove it. Unk mfg. It is a fiber modem in bridge mode. My ISP is passing me a static public IP address that I have on the RBR WAN interface via PPPoE.
Sep 30, 2024Guru - Experienced User
What is the brand and model # of the device(s) your connecting with Teams?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Any chance of asking the ISP about the brand and model# of the ONT?
Disable 20/40 MHz Coexistence unchecked.
Is SIP ALG enabled or disabled under Advanced Tab/Setup/WAN Setup?
- FredCCSep 30, 2024Guide
Thank you! Please see below:
What is the brand and model # of the device(s) your connecting with Teams? Dell Latitude 7420 Windows 11. Teams meetings worked fine with my Nigthhawk R8000.
Armor, Smart Parental Controls or Circle, Traffic Meter.With my initial troubleshooting, I disabled Armor. Same issue. I don't have Parental Controls or Traffic Meter enabled.
Any chance of asking the ISP about the brand and model# of the ONT? Yes, I will call support and get the info.
Disable 20/40 MHz Coexistence unchecked. I will uncheck and try another Teams meeting.
Is SIP ALG enabled or disabled under Advanced Tab/Setup/WAN Setup? disabled (checked).
I called my ISP support. The modem is a Calix model 812 wired fiber modem.
- FURRYe38Sep 30, 2024Guru - Experienced User
Is the the fiber modem you have?
https://www.minervavalley.online/wp-content/uploads/2020/04/812G_GigaHub_QSG_Viewable.pdf
https://www.newegg.com/p/0E6-01GN-00018
This has a router built in already if you have this. If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- FredCCSep 30, 2024Guide
This looks like the same modem, thanks for researching. Several months ago when I requested a static IP, they turned off router mode and placed it in modem/bridge mode. There is no NAT being performed on that modem. It is a non-wifi modem, wired only. My RBR is performing routing and wifi duties. I don't have a Teams meeting setup yet to test the 20/40 Mhz coexistence disabled. Could that setting alone cause the issue?
