myoufo
Mar 10, 2026Aspirant
Orbi RBE871 with RBS50
I recently bought an Orbi 870 series router RBE871 with one RBE870 satellite. I'm finding that my WiFi coverage does not seem as good as with my old Orbi RBR50 router and RBS50 satellite. If I try ...
Mar 11, 2026Guru - Experienced User
CrimpOn is correct. Its not compatible.
but the RBE870 should have better coverage than the RBR50 series. I've used both systems and the BE system has more coverage. I'd be investigating why yours doesn't. Whether its a satellite issue, a placement issue, or what. Some more details about your home coverage, how you're testing coverage, and any other details can help
