myoufo
Mar 10, 2026Aspirant
Orbi RBE871 with RBS50
I recently bought an Orbi 870 series router RBE871 with one RBE870 satellite. I'm finding that my WiFi coverage does not seem as good as with my old Orbi RBR50 router and RBS50 satellite. If I try ...
Mar 12, 2026Guru - Experienced User
I'd try the router option only first just to test. If you know it works, you can try do a little creative placements of the router/satellite to see if it can help the issue you're having. But first lets find out if thats the actual problem before developing a solution :)
