myoufo
Mar 10, 2026Aspirant
Orbi RBE871 with RBS50
I recently bought an Orbi 870 series router RBE871 with one RBE870 satellite. I'm finding that my WiFi coverage does not seem as good as with my old Orbi RBR50 router and RBS50 satellite. If I try ...
myoufo
Mar 12, 2026Aspirant
I won't have time to work on it again until Saturday. I plan to reconnect the old router and satellite and see if the cameras work better. If so, I'll send the 870 back to Amazon while I'm still in the return window. So far the only benefit I've seen from the 870 is slightly higher download speed with my 1GHz feed from Comcast. I don't want to give up the satellite because I'm using three of its Ethernet ports, and the placement options are limited. I will post again in a few days. Thank you all for your valued advice.
