B737Max
Dec 13, 2023Tutor
Orbi RBE971
My cell phone connects to Wi-Fi 6e and after a while switched to Wi-Fi 5g, I prefer the 6e, is there a way to setup the connection where my cell phone can always use 6e? Thanks
- Dec 14, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
B737Max
Dec 14, 2023Tutor
FURRYe38 you are my hero, the wireless 6E is working flawlessly and always active on my phone by using the phone mac address and not randomized, you should work for Netgear tech support, they had me move the satellite to a different location, this tech said it should be 5 or 6 feet off the ground and away from TV and other electronics, well that did not make sense, I did move it but when i saw no change i placed it back where my network area was.
Thanks again for your expertise.
Dec 14, 2023Guru - Experienced User
Enjoy. 📡
