mkassim3035
Oct 27, 2024Aspirant
ORBI RBRE 970 UN IDENTIFY NETWORK
I Purchased second hands orbi 970 Router , i replaced my old orbi 960 and connect with my laptop wired .but very strange its error shows in network NO INTERNET and also when i check network status it...
- Oct 27, 2024
Temporarily disconnect the PCs ethernet connection and connect it to the back of the RBR while it's ON. Don't have the RBR connected to the modem. Factory reset the RBR by pressing the Reset button for 15 secons then release. Wait 2 minutes, then open up a web page to see if there is a setup wizard waiting for you at 192.168.1.1.
There should be a paged displayed that shows set up using Nighthawk app.
Also have a phone or pad ready and with in the wifi settings of one of these devices, have it on the connect to wifi option so it lists near by SSID names. Look at the bottom of the RBR to see what the default SSID name is and after the reset is process, this SSID name should be displayed on the phone or pad. If you don't see this name or you don't see the initial setup web page, then the RBR maybe faulty. There is one last item to try if the above fails.
mkassim3035
Oct 30, 2024Aspirant
Thankyou ALL those trying to solved my problem ,it was good experience here and got lot of knowledge thankyou all
Finally my orbi 970 back in life . i contact netgear support first they refused me to solved my issue because it is 2nd hand unit , but i told and they see my ORBI Family account i used orbi from 750 to 970. all supervisor intervein and after long argument they come to help me out ,actually its bed software firmware they upload fm but tbh 2 or 3 download upload its very complicated sp for me but they spend 2 hours and finally done , also after all setup they again done factory setting this time its work as i do before with other orbi too .
thankyou NG and all on this forums
Oct 30, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
