Dwlaiche
Feb 21, 2025Follower
Orbi wifi7 not connecting to canon mx492
after setting up my Orbi WiFi 7 I can not connect my canon mx492 printer to wifi
Feb 21, 2025Guru - Experienced User
Try connecting the printer to the Orbi systems separate IoT network.
What security modes does the printer support.
Contact the printers Mfr for help and information regarding there printer and setup.
What model Orbi system do you have?
CrimpOn
This printer appears to support both WPS and SSID/password methods for connecting to WiFi.
(The WPS method is nearly foolproof. Have you tried it?)
If using the password setup, at what point does it fail?
