Ely
Mar 01, 2025Luminary
Orbi's main unit making clicking/rattling sounds
I'm experiencing this issue where my NETGEAR Orbi 970 Series Quad-Band WiFi 7 main unit is making this clicking/rattling noise, which it never did before. This has started happening exactly 4 months ...
- Apr 14, 2025
Over a week now, and I'm glad to report no issues so far with the new unit. It seems like there was def something wrong with the old one.
Apr 04, 2025Guru - Experienced User
Thanks for the update. Let us know how the new one turns out. Should be good.
Ely
Apr 14, 2025Luminary
- FURRYe38Apr 14, 2025Guru - Experienced User
Glad the new unit is working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
