RenayW
Nov 05, 2024Aspirant
Outdoor Satellite for Orbi 970
I recently bought the Orbi 970 3 pack. Signal strength is great in the house but doesnt extend to the backyard. I'm looking for an outdoor extender that will work with my system. I've tried to ca...
Nov 05, 2024Guru - Experienced User
There isn't a dedicated unit for the BE versions. The old AC had an outdoor rated unit but not the AX, AXE, or BE units.
A standard outdoor extender will work with them. If you're not needing the integration from orbi, you could pickup a different suppliers outdoor rated extender and use it.
