mapotter99
Jul 08, 2024Apprentice
Possible Fix for iPhone Dropping WiFi
I have an RBE973S system. think I have identified the reason my iPhone keeps dropping WiFi, and I wanted to share so others can see if it solves their issues. On your iPhone, go to Settings>Cellula...
donawalt
Sep 21, 2024Hero - Experienced User
I just changed to a manual IPv4 IP address, and manual DNS. Phone flipped to 5G, and even turning WiFi off/on it stayed on 5G. The WiFi setting says it's connected to WiFi, but the top right corner says '5G', and the speed test app confirms it is on 5G/using my AT&T cellular.
I have to say this iPhone 16 acts worse with 6E=Autonatic than the 15 does!
donawalt
I had to forget the network and re-add it to get it to connect again!
- Roc1Sep 21, 2024Luminarydonawalt , thanks for the update, you’ve saved me IPhone 16 money!!
I’ve followed your lead on the RBE971 issues this past year in configuring my IPhone 15 Pro Max, and 971 settings. The question I asked in my post about the iPhone 16 Pro Max, were mostly what I picked up from you! I thought we were on our way to a resolution! Maybe not.- donawaltSep 21, 2024Hero - Experienced User
Not yet it appears. I know they are working on it though.
- ClabontSep 22, 2024InitiateUnfortunately upgraded from my flawless RBE971 setup and now have constant drop off issues with my iPhones… seems most correlated to handoff situations which never ever posed an issue before.
Heard on Reddit that there’s an alpha/beta test happening with a potential fix… happy to help if anyone is able to share.
