Wornout
Dec 11, 2024Aspirant
printer won't connect to network
I just received my new wifi system (Orbi 970 Series Quad-Band WiFi 7 Mesh Router, Black Edition, 27Gbps) with 1 satellite. And it is SWEET!! My printer is an HP Smart Tank 7001. I have read through...
Dec 12, 2024Guru - Experienced User
Some printers/IoT devices struggle with the new standards and rarely get updated.
You might have better luck turning on the IoT network for the orbi and seeing if it'll connect to that.
Once its connected, might see if there's any firmware updates for it
or check with HP and see if they have any recommendations for connecting to wifi 7
