zaguama
Dec 11, 2023Aspirant
Problem with an iPhone 15 Pro Max
I’m having the exact same problem with an iPhone 15 Pro Max. Tried all of the steps mentioned above, running latest firmware as well and i still get intermittent drops on my phone. It will switch ...
zaguama
Dec 19, 2023Aspirant
Just updated this morning, will monitor for 24hrs and report back with the results, so far has been stable.
Dec 19, 2023Guru - Experienced User
- zaguamaDec 21, 2023Aspirant
Well not sure what exactly was done on this latest firmware but stability on my iphone 15 pro and pro max has definitely seen an improvement. In 48 hrs i think i saw twice a disconnect from the wifi to cellular, it’s moving in the right direction. Maybe the next update will see even better results.
- StraqDec 21, 2023NETGEAR Expert
FW V9.10.4.1 should not fix this issue. Issue should come back after a while.
We already have a fix for connectivity issues on phones, if need please reach out to me. The new firmware which still needs to go through quality assurannce testing. Only message me if you are okay with this.
In the meantime something that can be done on iPhone as well is the following :
Settings --> Cellular -->Cellular Data Options --> Voice & Data ---> 5G Auto to 5G On
5G Auto will allow iPhone to prefer Cellular Data over WiFi- zaguamaDec 22, 2023AspirantI sent you a DM, thanks!
