Billy1956
Jun 06, 2024Aspirant
Pump Spy
I Can't get pump spy connected to wifi? It is listed under web URL as allowed but not connected. I turned off Armor and I have the IOT turned off because I have no idea how to set up or connect certa...
- Jun 06, 2024
Enable the IoT network and connect it there?
Jun 06, 2024Guru - Experienced User
- Billy1956Jun 06, 2024AspirantThanks, I got it connected. But how do I tell what is connected to what network?
- CrimpOnJun 06, 2024Guru - Experienced User
The Orbi Attached Devices screen displays this information in the Connection Type field.
For example, a Samsung tablet was connected to the IoT network of an RBR750:
Notice the Connection Type is 5GHz - IoT
The tablet was then connected to the same router Guest network:
The Connection Type now shows 5GHz - Guest
Another interesting tidbit is that the RBR750 assigns IPs from the primary DHCP pool to both devices on the primary network (wired and WiFi) , but assigns IPs in the 192.168.2.x IP subnet to devices on the Guest network.
Thank You
- FURRYe38Jun 07, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
