Bones53
Jun 27, 2024Tutor
Random Internet Drops
I had an RBR50 with 4 satellites that was working fine but it seemed to be at capacity with all our wifi devices and cameras as it kept dropping some and re logging them on when it got to about 110 d...
kjx
Jun 29, 2024Apprentice
Your problems may or may not have anything to do with router overheating, but because the cost and effort to eliminate that as the cause is so low, so I'd suggest trying this:
Go to Amazon and buy one of those USB powered fan sets. I got "Dual 120mm USB Speed Control Fan, 5V Portable Cooling Fan for Flat-Screen TV Receiver Router DVR Playstation Xbox Computer Cabinet Cooler" - cost me $18.
Put them in series on top of the router sucking air upwards and out of the router. Report what happens after an extended period of time. I had all the symptoms you had before I landed on this as the solution.
Bones53
Jun 30, 2024Tutor
I am not sure its a heat problem. I would think there has to be some type of sensor for this that can determine the temp. L2 suggested I RMA the units I have and new ones that will be here monday I hope. After everything tech support has done, the problem still exists and seems to be getting worse. We cant even stream a movie without it dropping out now. The other day wile on phone with tech support L2, It took 30secs to over a minute to get the router logon screen. And then forever to load the home page. The PC is directly connected to the router as well. I was also told that the app should respond very fast with this new router and it can take 10 plus seconds to load page in the app. When I select traffic meter, it takes 10 or so seconds to load and when I go back and click on the traffic meter again, it takes just as long. With both these symptoms, Tech support thinks a new device will fix the problem. I am sure hoping so otherwise I dont know what to do. We cant run our business with all these drops and online meetings are impossible.
I am not very tech savvy and with that being said, this is just a standard (stock) setup. We use a lot of wifi devices, bit they are mainly light bulbs, power devices and a dozen or so amazon wifi cameras,
- FURRYe38Jul 01, 2024Guru - Experienced User
Please give feedback to the questions presented...
