Dilby
Aug 15, 2024Guide
RB970 Slow IoT network
Hi, I've been trying to diagnose issues with some of my devices - specifically Nest cameras. I set my IoT network to 2.4Ghz. When I connect an iphone 14 to the normal SSID I get around 280Mb...
Dilby
Aug 15, 2024Guide
I didn't think the "IoT Network" was an actually network and uses the same radio as the regular 2.4Ghz network. I thought the only difference was the SSID and what band the network identifies itself as.
CrimpOn
Aug 15, 2024Guru - Experienced User
Correct. There is one 2.4G radio, which broadcasts the primary, guest, and IoT SSIDs. All on the same WiFi channel.
