Artur2505
Feb 13, 2025Tutor
RBE 971 RESTART ISSUE FEW TIMES A DAY
I noticed for past few weeks that my router restarts few times a day without any reason But I noticed it happens when I'm turning on my PC that llan cable connected Any suggestions?
Feb 13, 2025Guru - Experienced User
Does the front LED turn PINK when this happens?
Can you check the RBRs debug page for system UP time and then compare to what is seen on the RBRs main web page under Advanced Tab/Connection stats/WAN port Up Time.
Debug is at the router IP address/debug.htm
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Do the RBS do same thing?
ow many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, IPv6, Smart Parental Controls or Circle, Logging, Traffic Meter.
- Artur2505Feb 13, 2025TutorFront led is pink when restarting yes
I do use Armor as well as security in app
To answer what channel I use I have no idea don't understand that and how to use or optimize
It's just On
I have 1 satellite 1 router 970/971
2200sq
V9.12.5.3 Just uploaded this morning
However restart issues happened before as randomly
I have lan 6 cable pretty good one- TOPS119Feb 13, 2025Luminary
I am having the same restart issue. @ points in the day my routers just restart automatically, How I notice is when the internet disappears from my laptop and tv looking at the router it flashes white and then auto connects after about a min or 2.
- FURRYe38Feb 18, 2025Guru - Experienced User
Armor, IPv6, All Logging on the RBR. Smart Parental Controls or Circle, Traffic Meter.Use Orbi app to disable Armor and SPC.
Log into to the RBRs web page to disable the rest.
Logging is found under Advanced Tab/Administration/Logging
To find what channels are being used, look at the routers web page on the Advanced tab. There is info showing what channels are being used.
It's just On
2200sq
