SuperTG
Feb 27, 2025Aspirant
RBE770 & RBE771 - satellite stops providing connection
I have the RBE770 Router with one RBE771 satellite (placed around 30 feet away, up one floor) in a standard 4-bed house. Regularly (sometimes multiple times per day) the satellite simply stops wo...
Feb 27, 2025Guru - Experienced User
A couple things to try.
1. move the satellite. Even though you stated those strength testings, things in walls, metal appliances, or other devices could cause interference. Sometimes a lateral move can help just as much as moving closer to get objects out of blocking the signal.
2. is the 240hz backhaul MLO enabled? (under advanced settings/wireless settings through the browser).
3. when it drops, what does the status page show under the orbi through the GUI for the satellite?
- SuperTGMar 13, 2025Aspirant
Hi plemans
1) I moved the satellite downstairs following your suggestion. The internet was fine for a week but now the same issue has occurred.
2) I've just enabled 200hz backhaul MLO. So will see if that helps.
3) Looking on the app, the Satellite shows as online with green bars, so it thinks it is still working.
Thanks
G
