SuperTG
Feb 27, 2025Aspirant
RBE770 & RBE771 - satellite stops providing connection
I have the RBE770 Router with one RBE771 satellite (placed around 30 feet away, up one floor) in a standard 4-bed house. Regularly (sometimes multiple times per day) the satellite simply stops wo...
Mar 27, 2025Guru - Experienced User
New FW available:
Noremorse11
Mar 31, 2025Tutor
New firmware installed, problem still occurs.
- FURRYe38Mar 31, 2025Guru - Experienced User
Just curious, have you swapped RBS with each other to see if the problem is only seen at the wireless connected RBS location?
What is the distance between the RBR and this wireless RBS location?
What devices do you have connected to this RBS?
- SivvisApr 09, 2025AspirantSame for me, i have one RBS771 and one RBS770.
I had the Hope that the last Firmware brings a change but still facing this issue for some weeks(it does not appaer from the beginning)
If you got any News from Support please Share 🙂- Noremorse11Apr 10, 2025Tutor
I have a beta firmware now but it hasn't fixed anything
- SivvisApr 11, 2025Aspirant
I create a ticket, lets see what netgear says...
For now i try the old firmware but only on the satellite (v.10.5.13.1) it was installed and restarted, the RBE771 router now says there were no updates for the satellite, but on the manual update tab the satellite appears as upgradeable device.
Let's see if this changes anything, for no it runs, but issues appear in my experience after 18-24 hours.
- DK21Apr 12, 2025StarMine hasn’t had the problem in a while. I updated the firmware to 10.18.3 and the next day it did. Hopefully it’s not going to be a regular thing again.
- FURRYe38Apr 12, 2025Guru - Experienced User
Ater updating the system to latest FW, and you saw one event, it hasn't done it since?
How was the system updated? Manually or automatic?
Have you performed a power cycle of the system since last update or continued to use after the FW loaded?
DK21 wrote:
Mine hasn’t had the problem in a while. I updated the firmware to 10.18.3 and the next day it did. Hopefully it’s not going to be a regular thing again.- DK21Apr 13, 2025StarNo, it hasn’t happened again. I updated manually and did not power cycle after install. I did after the router dropped all wireless activity, though. Hopefully it’ll remain stable or at least infrequent until it’s addressed.
