SuperTG
Feb 27, 2025Aspirant
RBE770 & RBE771 - satellite stops providing connection
I have the RBE770 Router with one RBE771 satellite (placed around 30 feet away, up one floor) in a standard 4-bed house. Regularly (sometimes multiple times per day) the satellite simply stops wo...
Noremorse11
Apr 10, 2025Tutor
Summary of my issues
1. 2 Satellites, 1 wireless and 1 wired, lose backhaul connection to the router at random number of days. Usually just the wireless but has also been both.
2. Router incorrectly reports which satellite a given device is connected to. Wireless satellite shows a device connected to it and the router shows that same device as wired to the router. Many cases of this. Satellite shows 8 devices connected and router shows 3 connected to that satellite.
3. Debug capture doesn't work after x days. I set it to capture (as instructed by support) until I notice a satellite is disconnected. When it happens I go to debug page and capture has been turned off by itself.
4. Satellites (every time the wireless and often also the wired) do not reconnect to the router after a router reboot. Usually 1-2 power cycles of the satellite to make it connect. Oddly, when this happens and the router shows satellite as disconnected I can still get to the satellite admin page by ip address.
I have owned almost every Orbi model since Orbi started and no other model over many years has acted as consistently badly as this extremely expensive model. Been in the same house all that time.
Apr 10, 2025Guru - Experienced User
I tried reproducing this on my 770 series before going to my 870 series. Could not reproduce this RBS issue or any issue related to the RBS. Wireless and wired RBS. Watched TV and streamed thru the RBS and gamed thru the RBS. Problem never presented it self, or days later and currently not seeing any issues on the 870 series with it's RBS wireless connected after putting it in place on 3/31.
Wondering if environment or something specific with maybe some connecting devices or maybe a total amount of devices could be a cause of this bad RBS behavior being seen.
