Bk1230
Dec 25, 2024Guide
RBE771 disconnects constantly
I have an RBE 771 mesh system, replacing my old RBR50, which I have used for MANY years without issue. But, we now have a much larger house and needed larger range. The two satellites on the RBE771 a...
Dec 26, 2024Guru - Experienced User
One thing to try is a factory reset. The RBE773 system is pretty new. Some of the firmware changes needed a factory reset afterwards to work properly. I actually have a 773 I test with with a wired backhaul and its been pretty rock solid. But I reset it after the last firmware change.
What modem/gateway is it connected to?
- Bk1230Dec 26, 2024Guide
It's connected to a Verizon fios modem. This is the reset where I paperclip reset each device?
- plemansDec 26, 2024Guru - Experienced User
yes factory reset with the paper clip.
Verizon really likes to use their own modem/gateway devices versus just standard ONT's. It causes a double nat.
do you know what gateway you have from verizon?
it's CR1000A and if there's a setting to change I will try it!
