ManpreetGoraya
Mar 02, 2025Initiate
RBE771 with 2 Satellite Mesh RBE770 - Freezing time to time - Requires reboot
I have been using this system since 2 months now and the main router is connected to ATT ( 1 GBPS) Router with two Satellite in different rooms to cover all devices. Time after time it freezes every ...
ManpreetGoraya
The ATT Modem model is BGW 320-500
I have a Cat 5E cable for the moment but I can order a CAT6A STP to see the difference.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended.
Okay, Yes it also has a active WIFI running though we are not using it. Let me disable the active wifi on Modem which we are not using. Thank you
- FURRYe38Mar 03, 2025Guru - Experienced User
Be sure to also use the modems DMZ or IP pass thru feature for the RBR.
