KevinLiT
Nov 22, 2024NETGEAR Moderator
RBE771/770 Firmware 10.5.13.1 is Available!
Hello Orbi Community,
Firmware version 10.5.13.1 is now available for installation. Manual update will be required for the devices that do not have the firmware available as an automatic update...
Barrykkli
Dec 01, 2024Aspirant
Would there be similar firmware fix for 2.4ghz issues on 970 series which obviously suffering from same issues.
- KevinLiTDec 02, 2024NETGEAR Moderator
Hello Barrykkli,
Welcome to the NETGEAR Community!
The current firmware for the RBE970 / RBE971 is Firmware Version 9.12.4.16 (for NA Region Only). This firmware enhances the following features:
Improved Wi-Fi and backhaul stability.
Improved system stability.
Improved client steering.
Improved speed test accuracy.If you are located in the NA region please download that firmware to resolve network instability:
https://kb.netgear.com/000066418/RBE970-RBE971-Firmware-Version-9-12-4-16-for-NA-Region-Only
For step-by-step instructions on how to successfully manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
Community Team
