KevinLiT
Nov 22, 2024NETGEAR Moderator
RBE771/770 Firmware 10.5.13.1 is Available!
Hello Orbi Community,
Firmware version 10.5.13.1 is now available for installation. Manual update will be required for the devices that do not have the firmware available as an automatic update...
Dec 11, 2024Guru - Experienced User
You need to use the WAN (Internet Port) MAC address. Not the LAN MAC address.
wallis97 wrote:
I'm having similar issues. Netgear support said it was due to double NAT with my AT&T gateway (BGW320-505). As recommended, I tried setting the AT&T gateway to IP Passthrough mode but I'm still having issues. I noticed that the Orbi RBE771 has two MAC addresses (LAN Port and Internet Port).
I configured the IP Passthrough using the MAC address that is on the back of the Orbi router (LAN Port), but I wonder if I should be using the other MAC address that shows in the Orbi config screen as "Internet Port". If someone could provide some feedback, I'd appreciate it. Thanks!
wallis97
Dec 25, 2024Aspirant
I switched the IP passthrough and still continue to have problems. Sporadic daily drops and ping spikes. Hope there’s a fix to this at some point.
- Bk1230Dec 25, 2024Guide
I tried the IP passthrough and immediately switched it back. I can't remember what was terrible - perhaps that it wouldn't use the wired satellites at all?
