KevinLiT
Nov 22, 2024NETGEAR Moderator
RBE771/770 Firmware 10.5.13.1 is Available!
Hello Orbi Community,
Firmware version 10.5.13.1 is now available for installation. Manual update will be required for the devices that do not have the firmware available as an automatic update...
Mythicque
Jan 21, 2025Aspirant
This is what the zip contains for me which doesn't work.
Jan 21, 2025Guru - Experienced User
How does that file not work? How are you unpacking the file and sending it to the RBS? That is the RBS file.
- MythicqueJan 21, 2025Aspirant
I extract the zip, go to orbi web page, go to manual update, select 1 satellite, select that file and upload it. But it gets stuck infinitely on the page in the screenshot.
- FURRYe38Jan 21, 2025Guru - Experienced User
Which Orbi web page? The RBR or RBS? You should be using the RBS web page to directly update the RBS.
The process does take a while before the web page will refresh. I've done this many times and it works.
Which web browser are you using? Try a different browser, FireFox or Opera. I use MS Edge. Works every time.
I'm using orbilogin. It doesn't matter if its RBR or RBS since when I select a satellite then click update, it pops up a window with the satellites ip anyways. I've been using brave, and tried edge but it still doesn't work.
