BLTPhd
Nov 01, 2024Aspirant
RBE771/RBE770 Connection issues to Samsung Smart TV. Only works on IOT network at 2.4GHz.
Upgraded my old RBR50 system to the RBE771/RBE770. Managed to get everything to reconnect except my Samsung Smart TV. The TV had no issues connecting to the old system. After much effort, I ...
- Nov 02, 2024
Yes the only way it will connect to internet is with IOT Network enabled at 2.4 GHz as I said in original post.
The TV will connect to the router with only the IOT 5GHz band enabled, but cannot successfully get an IP address and therefore cannot connect to the internet.
Nov 02, 2024Guru - Experienced User
what firmware is on the orbi?
Do you have wpa2/wpa3 mode selected for security? Don't use wpa3 only mode
BLTPhd
Nov 02, 2024Aspirant
Yes the both option is applied on main network. I even tried manually setting the network up on the TV and trying to force TV to use WPA2, WPA3, or mixed and that failed as well when trying to connect to main network.
