BLTPhd
Nov 01, 2024Aspirant
RBE771/RBE770 Connection issues to Samsung Smart TV. Only works on IOT network at 2.4GHz.
Upgraded my old RBR50 system to the RBE771/RBE770. Managed to get everything to reconnect except my Samsung Smart TV. The TV had no issues connecting to the old system. After much effort, I ...
- Nov 02, 2024
Yes the only way it will connect to internet is with IOT Network enabled at 2.4 GHz as I said in original post.
The TV will connect to the router with only the IOT 5GHz band enabled, but cannot successfully get an IP address and therefore cannot connect to the internet.
JWS9518
Nov 01, 2024Luminary
Looks like that TV was made in 2019 or 2020. Samsung is notorious for not keeping their TV firmware up to date. I have a Samsung as well and that has been my experience as well.
With that being said, sometimes older devices tend not to play nice with the newer security protocols of the newer Orbis (WPA3 and the combo of WPA3/WPA2).
Maybe try a factory reset of your TV and then power off both the TV and Orbi system and Sats for 30 seconds and see if that helps.
You should also report the issue to Netgear support as well.
IOT network is helpful for devices that are stubborn to connect like that. You could also use the guest network in a similar manner to help in the meantime as you can set those with WPA2 protocols only and 2.4 GHZ. At least until you get the issue worked out.
BLTPhd
Nov 02, 2024Aspirant
Samsung is really bad about supporting anything more than a few years old. I lean toward something in the authentication process handshaking, as really weird that I can get connect to router, but no IP assigned when IOT is set to 6GHz band but no connection when it is set to use both 6GHz and 2.4 GHz.
- FURRYe38Nov 02, 2024Guru - Experienced User
So to confirm you were able to get the TV working on the IoT 2.4Ghz then?
- BLTPhdNov 02, 2024Aspirant
Seems like something needs to be looked at by Samsung. 🤔
