Dakar15
Jan 12, 2025Follower
RBE771/RBE770 Orbi Loses connection constanly
Since I installed the Orbi 770 with the modem provided by SmartCity Telecom (ISP) I loose internet connection mostly twice a day. Moreover, I decided to force an IP Address lease renewal from the mo...
Jan 12, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
