lucapelo
Oct 28, 2025Aspirant
RBE871 slow speed
Hi All, just installed my brand new RBE871 and I’m getting a constant 94MB download/upload speed. If I connect my laptop to the ethernet port of the wall I get 850MB download. I have a main r...
lucapelo
Nov 04, 2025Aspirant
Thank, I'll try to plug the Orbi directly into the ISP router.
Yes I have a NON managed 1Gb LAN switch available, too. Are you suggesting to connect the Orbi 871 into the switch and not directly to the wall?
Nov 04, 2025Guru - Experienced User
Would be a good test if you can try the LAN switch in between the wall outlet and the RBR.
Please try the RBR directly connected behind the ISP router.
What brand and model# is your LAN switch?
