Rglaettli
May 19, 2024Guide
RBE970 Orbi 970 stops Broadcastin WLAN SSIDS
My Orbi 970 Stops broadcasting the WLAN SSIDs sometimes (about once a day) and all devices lose contact. I have to reboot the router. Opened a Netgear Case. But so far they only told me to factory r...
May 20, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can the ISP router be put online and used as the PPPoE handler for the ISP services?
Please contact NG support regarding this PPPoE issue with the 970 series. I believe they will need to take a look at this.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Can you post the top portion of the text data from the RBRs web page here? 192.168.1.1\debug.htm
Any features enabled on the RBR, Guest Network, Armor, Smart Parental Controls and IPv6?
Can you get a USB FAN to put on top of the RBR?
https://www.amazon.com/gp/product/B08ZSJFNMS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
- RglaettliMay 21, 2024Guide
unfortunatley admins put two vcompleatly different Problems in one here!
i dont understand the step of putting two compleatly different topics in one.. this will make it impossible for future readers to find it
First Problem Stop WLAN Broadcasting
The Stop of Broadcastig WLAN SSIDS i have allways. No matter what internet Provider/Modem i connect to.
And it does not have anything to do with the size of my home. The router stops broadcasting the SSID's. Thats a Fact.
all devices i talk about are less than4 meters from the router no walls.
Its not that the devices do not see the router. the Router stops Broadcasting
Are you really suggesting its an overheating Problem.. would be awful.. ill try but then im worried about summerSecond Problem The Problems with FTTH PPPoE i have only on my Fiber Provider.
As soon as i am Connected to the Fiber Provider Modem Zyxcel PM7300.TM XPON all Wired Connections have practically not Upload on all speed Tests. Dpownload is fast as hell. And see the linked Reddit Chat.. The user there has very exactly the same!!
Distance between satelites 3 m. wooden Floor... but i dont have a problem with Sattelites it all happens too when the Sattelite is turned of.
I was on it with Netgear support so far.. so no nothing at all is configured. Even the SSID is left original. No Access lists, Nothing is configured.
The Second Problem ist that the router simply does not reconnect to PPPoE after reboot. I Ordered a Router from My Provider that will do the PPPoE Login and i can user The Orbi behind it so i have a workarround soon..
Bit its Frustrating- FURRYe38May 21, 2024Guru - Experienced User
Thanks for posting the debug page information. That looks good here.
Actually size of home is a factor, why we ask for this size please. And how many RBS are deployed and distances between the RBR and RBS please.
Yes, seems that a couple of other posts from users have posted about putting a fan on top of the RBR unit seems to have stopped there odd diconnection or reboot problems. Something to try on yours.
Possible you also may have a faulty RBR as well.
The PPPoE issue will need to be handled by NG, I've already passed this along from the Reddit post and others over in the Orbi AX and AXE forums last year. Seems there maybe a wider Orbi issue with users with ISPs that require PPPoE that NG will need to take a look into. Other users have temporarily worked around this problem by putting in a different host router or use the ISP router to handle the PPPoE configuration and then configure there Orbi systems for AP mode, while NG gets this fixed. No idea when that will be so best recommendation is to open a support ticket with NG if you haven't already.
As i said the distance Between Satellite and router 1 3meters and there is a wooden floor in between.
All Problems i have appear also when the Sattelite i turned of.
I do not have a reboot Problem. The Problem i have is:
The SSIDs ar not broadcasted anymore. In this State The router is still connected to the Internet and Accessible vie Anywhere Access... Also Computers that conected via LAN still have Access to the Router.
To me it just looks like a defective Product!
Il try the thing with the fan BUT
If i really have to put an active cooler on my router i will have to return the Product. I payed a whole lot of money and expected a Roles Royce. il try this but its absolutley not acceptable.
- CrimpOnMay 21, 2024Guru - Experienced User
Bit its Frustrating
It may be time to RMA the system and request an extension on Netgear's 90 days of 'complimentary support'. (Switzerland may have regulations which affect that.)
We suggest trying the fan because it appears there may be manufacturing issues which result in overheating and it would be convenient to document whether this issue seems to be related to overheating (or not). A system that totally ceases broadcasting WiFi indicates a total failure of some key component that may have no 'cure' except replacement.
Thanks thats what i Think to, i never had a behaviour like this.
To me it looks like a devectice Device.
But what about the other Problem. The one with LAN Connected devices that do not get Upload Speed?
This problem is compleatly separated from the WLAN ISUE. (Still dont understand why the Threads where merged)
As Soon as The Orbi is Connected to the FTTH PPPoE Environement all devices that are conected by Wire (LAN) have no more (extreamly slow) Upload while Download is perfect.
To explain again i have two Providers:
a cable modem on that infrastructure i get download and upload OK
Fiber Modem ..FTTH PPPoE and i get very bad upload (only wired ..wlan is ok) Speedtest onm Router is 4GPPS Up and 4GBPS down.
Why i know its not the Provider.. because Everything on the now Provider works well with another router. And because i found a 7 month old redit Thread that describet exacrly the same... in the exaclty same environement. FTTH PPPoE i linked the Tread above.
This looks like a software/Firmware Issue. And should be quite Easy to Test for Netgear.- CrimpOnMay 21, 2024Guru - Experienced User
Have no experience with PPPoE systems. One suspicion is that the fiber ISP offers vastly more upload speed than systems have ever had before. (My cable upload is 12Mbps. WiFi devices are hard pressed to generate even a fraction of 4Gbps upload.
There seems to be ample evidence that "something is wrong" with the 971 router. Perhaps it affects both the WiFi signal and the upload speed?
