Rglaettli
May 19, 2024Guide
RBE970 Orbi 970 stops Broadcastin WLAN SSIDS
My Orbi 970 Stops broadcasting the WLAN SSIDs sometimes (about once a day) and all devices lose contact. I have to reboot the router. Opened a Netgear Case. But so far they only told me to factory r...
May 20, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can the ISP router be put online and used as the PPPoE handler for the ISP services?
Please contact NG support regarding this PPPoE issue with the 970 series. I believe they will need to take a look at this.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Can you post the top portion of the text data from the RBRs web page here? 192.168.1.1\debug.htm
Any features enabled on the RBR, Guest Network, Armor, Smart Parental Controls and IPv6?
Can you get a USB FAN to put on top of the RBR?
https://www.amazon.com/gp/product/B08ZSJFNMS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
CrimpOn
May 21, 2024Guru - Experienced User
It may be time to RMA the system and request an extension on Netgear's 90 days of 'complimentary support'. (Switzerland may have regulations which affect that.)
We suggest trying the fan because it appears there may be manufacturing issues which result in overheating and it would be convenient to document whether this issue seems to be related to overheating (or not). A system that totally ceases broadcasting WiFi indicates a total failure of some key component that may have no 'cure' except replacement.
- RglaettliMay 21, 2024Guide
Thanks thats what i Think to, i never had a behaviour like this.
To me it looks like a devectice Device.
But what about the other Problem. The one with LAN Connected devices that do not get Upload Speed?
This problem is compleatly separated from the WLAN ISUE. (Still dont understand why the Threads where merged)
As Soon as The Orbi is Connected to the FTTH PPPoE Environement all devices that are conected by Wire (LAN) have no more (extreamly slow) Upload while Download is perfect.
To explain again i have two Providers:
a cable modem on that infrastructure i get download and upload OK
Fiber Modem ..FTTH PPPoE and i get very bad upload (only wired ..wlan is ok) Speedtest onm Router is 4GPPS Up and 4GBPS down.
Why i know its not the Provider.. because Everything on the now Provider works well with another router. And because i found a 7 month old redit Thread that describet exacrly the same... in the exaclty same environement. FTTH PPPoE i linked the Tread above.
This looks like a software/Firmware Issue. And should be quite Easy to Test for Netgear.- CrimpOnMay 21, 2024Guru - Experienced User
Have no experience with PPPoE systems. One suspicion is that the fiber ISP offers vastly more upload speed than systems have ever had before. (My cable upload is 12Mbps. WiFi devices are hard pressed to generate even a fraction of 4Gbps upload.
There seems to be ample evidence that "something is wrong" with the 971 router. Perhaps it affects both the WiFi signal and the upload speed?
- FURRYe38May 22, 2024Guru - Experienced User
What happens if you put the RBR behind the cable modem instead of the Fiber ONT?
This looks like a software/Firmware Issue. And should be quite Easy to Test for Netgear.- RglaettliMay 22, 2024Guide
When i put the Orbi behind the Cable Modem i have the normal Speed on my wired connections
But i know its not a provider issue because if i put another router behind my Fiber provider i get all speeds correct.
So it is defnetley a combination of the Orbi970 and a Synchrron FTTH PPPoE Setup.
