JustinThyme
Nov 25, 2023Guide
RBE970 wired backhaul
Been trying for a few days to get one of the Satellites to connect with a 10Gbe wired backhaul. The culprit is the add on. Lastest FW, brand new system. It will connect plugged in directly to 973 rout...
- Dec 13, 2023
We have a fix for Managed Switch issue. You do not need to do any changes on Orbi side. However, there is probability some managed switch might have looping protection, this will need to be disable. We will be writing a KB article regarding this. In the meantime, please reach out to me directly to receive latest firmware with the managed switch fix
Jrphammer
Dec 13, 2023Aspirant
I am reaching out to you directly to receive latest firmware with the managed switch fix
JustinThyme
Dec 13, 2023Guide
Send a PM to Straq for request. Response isn’t instant but you will get a reply.
- FURRYe38Dec 19, 2023Guru - Experienced User
- JrphammerDec 20, 2023Aspirant
5 days since a pm to support. Still have not sent me any software. READY TO SEND IT BACK.
- JustinThymeDec 20, 2023GuideThe newest FW is released and not beta anymore. It can be easily updated in the web UI. I updated mine last night and as soon as I get a chance I’m going to put my managed switch back in the loop to see how it reacts. That was my only problem as I was trying to do a wired connection to one of 3 satellites just to offload the backhaul. Using a different switch and it works fine before the latest FW release. Going to verify the operation of the managed switch and provide feedback here. No other issues. Coverage is great and no drop outs.
