zaguama
Dec 03, 2023Aspirant
RBE971 + 2 RBE970 Satellites Wireless Backhaul Topology
I upgraded from Orbi Mesh Wifi 6 platform (1 Router + 2 Satellites), to this new Wifi 7 platform (same 1 Router + 2 Satellites) setup. With my previous wifi 6 mesh system the “algorithm” decided th...
- Dec 03, 2023
Would need a diagram from top down and mark where the RBR and RBS are placed.
WIth concrete material in the mix, this would be a factor in how the system is detect and connecting to the RBS.
If you turn OFF RBS A and B, then turn on RBS A first and let it sync, after it's connected, turn ON RBS B, see if this might get RBS B to connect to RBS A. MIght mode RBS B a bit closer to RBS B maybe.
zaguama
Its a two story house, concrete walls all around. I got main router on a “network room” with window access on top floor, satellite A about 50 ft away on top floor and satellite B on bottom floor kind of in between main router and satellite A.
Previous Wifi 6 i’m guessing wasnt powerful enough so satellite B preferred Daisy chain but on this new platform seems to prefer to link directly to the main router. Since Netgear does all behind the scenes and doesnt reveal much to the end user cant really tell if this is the optimal topology indeed or the algorithm might needs some more optimizations.
I know this is a new platform and is not mature enough as Wifi6, that’s why i opened this discussion.
Dec 03, 2023Guru - Experienced User
