SM004346's avatar
SM004346
RBE971 additional Access Points
Hi, I need to extend my WiFi coverage to some far areas, not reachable through the Current mesh setup: one RBE971 + 2 Satellites.  Which are the suggested wired Access Points to use (e..g. WAX 620 o...
  • plemans's avatar
    Jan 21, 2025
    You can wire in the EAX80. If its far enough away, your devices own roaming protocol will work fine and you can name them the same. Just set it up in access point mode and make sure the wireless channels used aren't the same to prevent interference.
