Ritobu
Dec 02, 2023Aspirant
RBE971 and 2 satellites - Cannot connect Google Home - "Turn off AP isolation...?
Hello, I've been using the new Orbi 970 series BE27000 Mesh System for just under 2 months now and it seems like I've just experienced one problem after the other. My recent issue, which brin...
- Nov 03, 2024
I spent hours trying to fix this issue only to find out that uninstalling and reinstalling Google Home and accepting all of the permissions when reinstalling resolved everything. I was changing all kinds of router settings I saw posted on user forums this afternoon only to find out in the end that the issue had nothing to do with my router. Others may want to give this a try if they come across this thread.
bluemus
Nov 03, 2024Aspirant
Nov 04, 2024Guru - Experienced User
Glad it wasn't a orbi issue. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
