grosjean
May 17, 2024Tutor
RBE971 constant ethernet disconnections
Hi all, I regularly observe ethernet disconnection of the RBE971 (firwmware V9.12.2.1_1.2.10) Setup is set as follow: RBE971 in AP Mode connected throught ethernet to a Linux router, ethernet card...
May 18, 2024Guru - Experienced User
are you going:
Linux router----->wan port on 971--->lan port out----->971 satellites?
What linux router is it?
What gateway is the linux connected to?
- grosjeanMay 18, 2024Tutor
Hi Plemans,
The linux router is connected with fiber to my ISP, meaning that i maintain my own router here, which have always worked.
ISP ---> Linux Router ----> Wan port on 971 -----> Wifi BlackHaul ----> 970 Satellite
I tried the 10g wan port, the 10g ethernet port, and all 2.5g ethernet port on the 971 with same results.
- plemansMay 18, 2024Guru - Experienced User
have you tried going ISP gateway--->Orbi?
Pull out the linux gateway to see if its causing an issue.- grosjeanMay 18, 2024Tutor
plemans wrote:have you tried going ISP gateway--->Orbi?
I can't consider this solution, as my router is working perfectly.I got this problem only with the RBE971 connected to it, other servers connected to the router behave correctly.
