grosjean
May 17, 2024Tutor
RBE971 constant ethernet disconnections
Hi all, I regularly observe ethernet disconnection of the RBE971 (firwmware V9.12.2.1_1.2.10) Setup is set as follow: RBE971 in AP Mode connected throught ethernet to a Linux router, ethernet card...
May 18, 2024Guru - Experienced User
are you going:
Linux router----->wan port on 971--->lan port out----->971 satellites?
What linux router is it?
What gateway is the linux connected to?
grosjean
May 18, 2024Tutor
Hi Plemans,
The linux router is connected with fiber to my ISP, meaning that i maintain my own router here, which have always worked.
ISP ---> Linux Router ----> Wan port on 971 -----> Wifi BlackHaul ----> 970 Satellite
I tried the 10g wan port, the 10g ethernet port, and all 2.5g ethernet port on the 971 with same results.
- plemansMay 18, 2024Guru - Experienced User
have you tried going ISP gateway--->Orbi?
Pull out the linux gateway to see if its causing an issue.- grosjeanMay 18, 2024Tutor
plemans wrote:have you tried going ISP gateway--->Orbi?
I can't consider this solution, as my router is working perfectly.I got this problem only with the RBE971 connected to it, other servers connected to the router behave correctly.
I can't consider this solution, as my router is working perfectly.----You think it is. But not 100% unless proven. I've ran modem--->gateway---->orbi solutions. Never had an issue with the orbi's.I got this problem only with the RBE971 connected to it, other servers connected to the router behave correctly.
