breaksfr123
Apr 01, 2024Guide
RBE971 Firmware Version 9.12.2.1 Issues
Hi I upgraded my Orbi system (1 router + 2 x satellite) approximately one month ago, and upon installation through the Orbi app, it automatically updated the firmware on all 3 devices to V9.12.2.1_1....
May 28, 2024Guru - Experienced User
Any progress on this?
breaksfr123 wrote:
Hi I upgraded my Orbi system (1 router + 2 x satellite) approximately one month ago, and upon installation through the Orbi app, it automatically updated the firmware on all 3 devices to V9.12.2.1_1.2.10.
I did as per usual and personalised the settings to broadcast the existing SSID of my router and when doing so noticed a new network with SSID "NTGRBH_[MAC address]", which I found unusual. I then checked the MAC address of my router and also verified via the native WIFI scanner on my iPhone and see that the MAC addresses differ by one letter.
This leads me to believe it must be broadcasting some sort of backhaul channel (you'll forgive any misuse of jargon please!).
Whilst this is most likely not problematic, it doesn't seem ideal to be broadcasting MAC addresses like this. I phoned netgear who, after speaking with not less than three agents over three days, scheduled a call back which I received this afternoon.
Netgear says that this is a known issue that will be corrected by way of a firmware update...with no ETA.
Is this something I should be worried about?
Ah, and my satellites wont reconnect if I reboot my router. I have to factory reset them each time, otherwise they both go magenta despite having a great connection when they do successfully connect.
Could these two issues be related?
For info, my ISP set up is with Community Fibre and gave 3gb up/download and have the orbi router connected to an Adtran ONT.
Thanks!
breaksfr123
May 28, 2024Guide
Hello,
I have reset the system with Orbi tech support more times than I can remember. Level 2 support said that this is a known issue (i.e. the broadcasting) and would hopefully be addressed in a future firmware release.
I am still working with them regarding the satellites not connecting after rebooting the Orbi router and have sent 3-4 sets of debug files. They just keep coming back asking me to do a slightly different procedure than the previous time.
I'm a bit fed up by this point to be quite honest. The system is expensive, and I do not think it is fair to expect this level of involvement from a consumer to find the issue, which must either be the firmware or the device.
I would not have thought that broadcasting the MAC address would be a function of the channel configuration (auto for 2.5 ghz and 48 for 5 ghz), the distance between satellites (30+ feet between each) or how many satellites I have deployed (3 satellites in all). Why would this cause the mesh to expose a backhaul channel (not sure this is the right term)?
Thank you
- FURRYe38May 28, 2024Guru - Experienced User
I would ask them about a RMA at this point.
Yes the backhaul broadcast is a known thing. It's been there since the beginning. It does not cause problems from the RBS or to the RBS. You can ignore that for now.
However if the RBS are having issues getting connected to the RBR and keeping connected, I'd ask for an RMA. Yes this system is too expensive to be hassling with all this troubleshooting. I'd ask about an RMA for sure. Do you have a case number by chance?
- breaksfr123May 31, 2024Guide
Thank you for your reply.
I will ask for an RMA, presumably by speaking to the technical team?
Also, I followed your instructions regarding the reset and the satellites (2 that came with the orbi router and 1 add on) did the same thing (i.e. not connecting unless I reset them and then dropping each time the ORBI router is rebooted).
The case number is 48126355.
Thank you
- FURRYe38May 31, 2024Guru - Experienced User
Yes ask thru the case number you have there.
- CrimpOnMay 28, 2024Guru - Experienced User
FURRYe38 commented already that Netgear is aware of the goof regarding broadcasting the backhaul channel SSID. Since the first Orbi model (2016) Netgear has given the backhaul channel a goofy name that is intended to be "sort of unique" to each router and has not broadcast the SSID. My ancient RBR50 backhaul has the SSID NETGEAR_ORBI_hidden41 The "41" obviously came from the default WiFi SSID ("ORBI41") and implies that the chances of a neighbor having an Orbi system with the same backhaul is roughly 1 in 100. The backhaul password is a combination of 63 random characters, so even if there were an identical Orbi system next door, satellites for each would be able to connect only to the appropriate router. Changing from the default Orbi SSID to using part of the hardware MAC address probably seemed like a cool way to make the odds of two systems having identical backhaul SSIDs practically zero.
p.s. At one time, not broadcasting WiFi SSID was touted as a security measure and recommended by some "WiFi Gurus". Over the years, people discovered that this sense of seurity was false because there are techniques for learning the SSID. See, for example:
https://www.acrylicwifi.com/en/blog/hidden-ssid-wifi-how-to-know-name-of-network-without-ssid/
Thus, Netgear does not broadcast the backhaul SSID as a security measure. It is simply a way to keep from cluttering user WiFi devices with WiFi SSIDs that they cannot possibly connect with (because they do not know the 63 character password).
Fair enough, however if this was "normal" behaviour then it should be highlighted in the manual, which it is not.
Furthermore, this does not solve the problem I am having with the satellites not connecting.
Thank you
Ya I now, normally you should see the BH SSID, and again at some point, NG hopefully will make that hidden.
Let us know how it goes with support.
