Artur2505
Nov 03, 2024Tutor
RBE971 iphone is keep disconnecting and room 15ft away no connection
I don't know what's going on but I had orbi 6e mash and never had any problems before Room next to other room where is router connected, my phone is not working with wifi Usually few times a day ran...
Nov 04, 2024Guru - Experienced User
Does this happen with the RBS turned OFF?
What model iPhone do you have?
What iOS is loaded on it?
If the iPhone is a later model with 6Ghz support, try disabling 6Ghz feature on the phone and check for this problem...
What channel configurations are currently set on the router?
