jdharrisonsouth
Jan 02, 2025Guide
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be...
- May 01, 2025
And hows your system doing?
jdharrisonsouth wrote:
All quiet here - no reboots - still monitoring...
jdharrisonsouth
Jan 23, 2025Guide
LED on RBE971 flashes white when this happens - boot cycle.
WAN port uptime stats show as if the router had been hard-booted - counters have been reset. logs showing INIT messages. System uptime is only a few seconds or minute when you can get in to check logs.
The fiber bodem is Spectrum - SONUV1H.
Cables have been replaced with new "Cat 8" cables recently purchased.
Curious - on the question for the fiber modem - are there situations where that would cause the ORBI to reboot? I would not have expected that. I could see the ORBI going to the purple color status if the fiber modem freaks out or reboots. But should we expect the ORBI to stay running through an event like that?
Jan 23, 2025Guru - Experienced User
Anything is possible when connected to any modem or ONT from what we've seen.
Possible some memory leak issue or CPU could be getting over usage as well that may cause this.
What all is connected to the system?
Does this happen if you turn OFF the RBS?
- jdharrisonsouthJan 26, 2025Guide
Appreciate the suggestion about code issues (memory & CPU) - reaching out with a formal case to warranty support.
Network topology is simply the fiber modem connected via cable to the RBE - then 2 satellites connected wirelessly to the router.
End points range from iphones, ipads, mac pro, macbooks, thermostats, washer, dryer, printer, ring cameras & doorbell, simplisafe, Nintendo switch(es), apple TVs, garage door opener... about 29-30 total most times of the day
Sounds like a suggestion is to unplug the satellites and see if things change?
