jdharrisonsouth
Jan 02, 2025Guide
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be...
- May 01, 2025
And hows your system doing?
jdharrisonsouth wrote:
All quiet here - no reboots - still monitoring...
CharCast
Feb 06, 2025Aspirant
I have moderate confidence I figured out the cause of my random reboots.
There was a failing dehumidifier on the same AC circuit. That was likely causing an excessive amp draw and corresponding voltage drop that the router power supply could not deal with. Since taking the dehumidifier offline on Monday I’ve had no uninitiated reboots.
To the rest of you, consider monitoring your available AC voltage. I was trying to figure out how to best do this. Search Amazon for "AC WiFi Watt Meter, Plug-in US Socket Power Meter, Backlit Large Color Display, Overload Protection, Kilowatt Wattage Voltage AMP Tester, Electrical Energy Monitor,Delay to restore power supply, Timer". A device like this should allow for low voltage to be confirmed or ruled out.
Feb 06, 2025Guru - Experienced User
Good find. Glad you figured it out.
Something you might consider installing a UPS or some form of power cleaner unit to help keep the power at the power brick to the RBR in good working order.
Thanks for letting us know.
There was a failing dehumidifier on the same AC circuit. That was likely causing an excessive amp draw and corresponding voltage drop that the router power supply could not deal with. Since taking the dehumidifier offline on Monday I’ve had no uninitiated reboots.To the rest of you, consider monitoring your available AC voltage. I was trying to figure out how to best do this. Search Amazon for "AC WiFi Watt Meter, Plug-in US Socket Power Meter, Backlit Large Color Display, Overload Protection, Kilowatt Wattage Voltage AMP Tester, Electrical Energy Monitor,Delay to restore power supply, Timer". A device like this should allow for low voltage to be confirmed or ruled out.
- CharCastFeb 06, 2025Aspirant
You are spot on. It was the actually the logs from my UPS that help me pinpoint what was happening.
