jdharrisonsouth
Jan 02, 2025Guide
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be...
- May 01, 2025
And hows your system doing?
jdharrisonsouth wrote:
All quiet here - no reboots - still monitoring...
Feb 07, 2025Guru - Experienced User
Curious and queston for those of you in the thread, what logging on the RBR is enabled?
Would you try disabling ALL Logging on the RBR and see if you still notice this reboot of the RBR?
jdharrisonsouth TOPS119 CharCast Roc1 donawalt
jdharrisonsouth
Feb 07, 2025Guide
I've got all logging options enabled - but the only data I see in the log are the DHCP entries and admin login... very little other messages...
- donawaltFeb 07, 2025Hero - Experienced User
jdharrisonsouth can you try de-selecting all the message types to be logged, reboot your Orbis, and see if you get any phantom reboots/crashes? Leave the DoS checkbox selected, but you wonât have any/many of them..
- jdharrisonsouthFeb 07, 2025Guide
I'll have to come back to this in a little bit. I'm in the middle of a check for Netgear support - not sure I want to change something under what they're already asking from me.... changing one thing at a time as long as they are still engaged with me on that support case. đ
