jdharrisonsouth
Jan 02, 2025Guide
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be...
- May 01, 2025
And hows your system doing?
jdharrisonsouth wrote:
All quiet here - no reboots - still monitoring...
jdharrisonsouth
Feb 07, 2025Guide
I've got all logging options enabled - but the only data I see in the log are the DHCP entries and admin login... very little other messages...
donawalt
Feb 07, 2025Hero - Experienced User
jdharrisonsouth can you try de-selecting all the message types to be logged, reboot your Orbis, and see if you get any phantom reboots/crashes? Leave the DoS checkbox selected, but you wonât have any/many of them..
- jdharrisonsouthFeb 07, 2025Guide
I'll have to come back to this in a little bit. I'm in the middle of a check for Netgear support - not sure I want to change something under what they're already asking from me.... changing one thing at a time as long as they are still engaged with me on that support case. đ
