jdharrisonsouth
Jan 02, 2025Guide
RBE971 reboots
RBE971 randomly rebooting daily. Sometimes it will reboot and come back on line after 2-3 minutes of disruption - other times the wireless for router & 2 satellites completely shuts off and must be...
- May 01, 2025
And hows your system doing?
jdharrisonsouth wrote:
All quiet here - no reboots - still monitoring...
jdharrisonsouth
Mar 18, 2025Guide
I had been trying to stick with Netgear Support if their recommendations (keep logging on) were conflicting with the recommendations in the community....
I need to revisit that approach - especially with the lack of progress on the support case
donawalt
Mar 18, 2025Mentor - Experienced User
jdharrisonsouth Logging (the kind you send support) should not be running all the time. If something occurs, you can turn on logging for 5 minutes and get everything they need. Logging on all the time will make huge files of data. Be sure on the debug page for the router AND satellites, these are turned OFF (first image) and all the logging checkboxes are unchecked on the router admin web page, advanced tab, advanced section, logs (second image):
