Bonnerl07
Jan 31, 2024Tutor
RBE972SB - IPv6 stops working
IPv6 quits working shortly after enabling it.
Jan 31, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How do you have IPv6 configured on the RBR?
Who is the ISP service your connecting with?
Be sure the ISP is supporting native IPv6 from there services.
Be sure to contact the ISP to check for any IPv6 specific configurations that maybe needed on the RBR>
Bonnerl07
Jan 31, 2024Tutor
Modem: Arris SB8200
Provider: Xfinity
RBE970 firmware: v9.11.0.1
Ethernet: Cat6 verified (not fake CCA Ethernet)
IPv6 is supported (works fine with my RBR750 Orbi system)
IPv6 settings: DHCP and the LAN is set to Auto Config
Provider: Xfinity
- FURRYe38Jan 31, 2024Guru - Experienced User
OK, There seems to be already a known issue with IPv6 and Orbi 970 series. Something that NG is aware of. No idea when a fix will be forth coming. You might want to contact NG support and let them know as well of what your seeing.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".All we can do for now.
