Havok_
Sep 26, 2024Star
RBK853 vs RBE973
Hey everyone. Hoping someone could share some real world experience... I currently have an RBK853 system. While getting 1GB at the router, the speed drops significantly to sub-300 in my office....
- Sep 27, 2024
I neglected to mention Multimedia over Coaxial cable (MoCA - https://en.wikipedia.org/wiki/Multimedia_over_Coax_Alliance ) There was a time when most houses had television coax running through the house to almost every room. (much like that old telephone cable was run throughout the entire building!) MoCA is capable of very high speed, and the adapters are also inexpensive.
CrimpOn
Sep 26, 2024Guru - Experienced User
Havok_ wrote:
Does the RBE973 use different backhaul frequency/technology that penetrates walls better so I'd see better speeds? Realizing that over wireless, the backhaul will suck vs wired, is it better on the 970 series?
Yes, the 970 product uses WiFi7 encoding (802.11be) for the WiFi link between router and satellite. While the actual radio frequencies are affected by distance and building materials the same way the 850 product WiFi link is, the encoding may result in a higher transmission rate than the 850. As with all WiFi, this link remains "Half Duplex", meaning that when one radio transmits the other radios must listen. The 853 has one router and two satellites, so all three share the 5GHz link. It would be an expensive experiment to discover how much greater performance would be delivered by the 970 product.
Powerline adapters are a much less expensive experiment (under $100 for two). Powerline is also affected by distance, condition of the electrical wiring, and passage through circuit breakers. The highest performance is when two adapters are on the same electrical circuit and are not very far apart. (I have a pair of TP-Link 9020P adapters on the same circuit which report a link rate** of over 1,300Mbps in both directions. A third adapter that is on a different electrical circuit and is more than twice as far away reports only 340Mbps in one direction and 340Mbps in the other.
** TP-Link provides a utility (Windows) which reports information about their Powerline adapters. I have not found a similar utility for Netgear Powerline adapters.
Like WiFi, Powerline is inherently "Half Duplex". All the Powerline adapters on the electrical grid share the bandwidth.
There certainly is a chance that Powerline will improve performance to this satellite. Testing the hypothesis will be relatively inexpensive. (I LOVE this kind of experiment!)
Another inexpensive test would be to purchase a 100ft. Cat6 Ethernet cable (under $20 on Amazon). Ethernet is inherently "Full Duplex". Data flows in both directions at the same time. Also, Ethernet has dramatically less overhead than WiFi (or Powerline). Pick a time when stringing a cable through the house will not a tremendous distraction and connect the router and satellite over the cable. Within five minutes or so, the link should change from 5GHz WiFi to 'Wired'. Measure the speed. Is the increase in speed significant enough to make a difference? If so, it is time to consider the cost/inconvenience of installing a cable vs. the increase in performance.
If you do either experiment, please return to the forum and share the results.
Havok_
Sep 26, 2024Star
Thanks for the info, it was helpful.
I actually did just order the TP-Link TL-PA9020P KIT you mentioned for the test. 🙂
I also already tested with a 100' Cat6 cable and yes, wired absolutely rocks. Nearly full speed. After this little test with the powerline adapters, we will indeed decide how to proceed with wiring. Since I was just kinda forced by Xfinity into their 2gb service (no data cap), more speed is better.
- FURRYe38Sep 26, 2024Guru - Experienced User
Let us know if the PLs work for you.
- Havok_Sep 27, 2024Star
Unfortunately, the Powerline Adapters are a dud for the need at hand. The secret for their max speed, is all should be on the same circuit, which is just horrible. If I'm close enough to not have to go through a breaker panel, then Wi-Fi wouldn't ever be a problem.
Max speed I can get out of them is 125Mbps.
That being said, I won't be sending them back as I do have an application for a Sonos in my garage in which these should work great. 🙂
But's it's a dud for getting more speed from Orbi into my office.
- FURRYe38Sep 27, 2024Guru - Experienced User
Any chance of having someone fish and run same CAT6A STP cabling from the RBR location to the office location?
