Echostorm
Apr 02, 2024Guide
Re: I am having the worst disconnection problems imaginable
My 2.4 Ghz Devices are unusable they constantly disconnect! I even bought MORE satellites so that I now have 4 satellites so my IoT coverage is impeccable HOWEVER this has made things worse as satel...
Straq
Apr 05, 2024NETGEAR Expert
Hi Echostorm ,
Can you please enable IoT Network with 2.4GHz only. Please note any devices connected to your IoT Network will be able to communicate with your main network. Main network uses WPA2/WPA3 security which might cause issues. IoT Network has WPA2 security which has help many customer with their IoT issues.
You can do this by going to your router admin login page. Go to wireless setting and enable IoT. Make sure it is a different SSID than your current main network.
Ex)
Main Network SSID: "Wireless 1"
IoT Network SSID: "Wireless 2"
You can also instead move the Main Network SSID to the IoT Network so that you do not have to reconnect your IoT devices. Make sure to rename your Main Network SSID to something else.
Ex) Before:
After:
Main Network SSID: "Wireless 2"
IoT Network SSID: "Wireless 1"
- EchostormApr 05, 2024GuideSorry to clarify all my 2.4 GHz are already on a dedicated IoT network channel 11 (there’s an issue with Sonos speakers on other channels), what I noticed from my garage door opener is that it treats the IoT network the same even though there are 5 of the same IoT network in range, when it decides to roam between the satellites (I can see it connecting in the Orbi app) to the one furthest away with the weakest signal is will continuously drop. It seems like there should be some optimization from the router to prioritize its strongest connection and or to disallow it to connect to a weaker satellite. better
- FURRYe38Apr 05, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the size of your home? Sq Ft?What devices do you have connected in total?
What channel configurations are currently set on the router? Try channel 6 and 40 or 44.
Are you using the separate IoT network for the IoT devices?
Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
If you turn OFF the farther RBS that this one device connects to, does this device connect to a near RBS or the RBR?
Firmware Version
V9.11.1.1_1.2.2For example my Withings body scale that used to work fine for YEARS now cannot connect to to my 970's mesh network it is 2.4 Ghz only. Funny thing with the scale and with the garage door opener is that they they keep throwing "incorrect password" connection errors (even though my password is correct). It can see my IoT network but it cannot connect. So with this happening with multiple 2.4 Ghz only items, it seems there's seriously something wrong with 970's 2.4 Ghz network compared to the 860 that I upgraded from.
My 5Ghz + 2.4 Ghz devices work flawlessly throughout the whole house
As for the personal details Straq is looking at my network privately
